Toyota Caldina Model 2WD&4WD (2002-2007) - manual repair, maintenance and operation of the vehicle.
Presented at book4car.net guide describes step-by-step procedures for operation, maintenance or repair of the car Toyota Caldina produced in the period 2002-2007. Caldina equipped with engine models 1AZ-FSE (2.0 l D-4), 1ZZ-FE (1.8 liters) and 3S-GTE (2.0 liters).
The publication manual provides the detailed data to check and repair engine management systems Toyota (with direct fuel injection = D-4), systems of change of phases of gas distribution (WT-i) system turbo-boost. In the book there are instructions for use by the owner of the system self-diagnostic engine, automatic transmission, ABS (brake system), TRC, VSC, BA, SRS. In the manual of printed instructions for adjustment and repair of automatic gearboxes, Toyota, anti-buccofacial system (TRC), stability control (VSC), emergency braking (BA). A separate section of the repair manual Toyota Caldina given codes possible faults of the car and described the test of master control unit engine, automatic transmission, ABS, BA, systems, TRC, VSC.
The book has electrical diagrams Caldina, description of checks of elements of an electric equipment of the car.
Given numbers of spare and replacement parts, according to the directory for scheduled maintenance Toyota Caldina.
