Guidance on repair and maintenance of Acura MDX, Honda Pilot, Honda Ridgeline, produced in 2001. These vehicles are equipped with a gasoline engine models J35 (volume of 3.5 liters).
The guide gives a description of the work to repair, adjust, the main elements of the engine control system, the VTEC system changes the height of the valve lift, automatic transmission, - automatic transmissions. The book contains the instructions for using the system self-diagnosis: - automatic transmission, VSA, VTM-4, TPMS - system testing of air pressure in the tires, SRS. The instructions to perform the adjustment and repair of gearboxes, brake system (including VSA), steering and suspension.
