The book is a manual Mitsubishi Pajero IO. The book is a guide for the operation and maintenance of Mitsubishi Pajero IO, which were issued between 1998 and 2007. These cars were equipped with gasoline engines models, "4G93" MPI (the volume of 1.8 liters.), "4G93" GDI (volume -1,8 liters) and "4G94" GDI (volume to 2.0 liters).
In the manual there is data for performing diagnosis of the condition and breakage, repair and adjustment engines, main control systems of the engines (this is the ignition and fuel injection system the MPI and GDI), other. In the book there is a section on adjusting the automatic transmission and control system all-wheel drive Mitsubishi Pajero - SUPER SELECT 4WD and FULL TIME 4WD. There is information on how to adjust and repair braking system (ABS), steering and suspension systems of automobiles. The guide describes the possible faults and malfunctions of the car on the way and the methods for their independent and quick fixes. There is a section showing the mating dimensions main components and parts, showing the limits of their allowable wear, recommended lubricants and other necessary fluids.
In this book there is a manual Mitsubishi Pajero IO has recommendations for proper maintenance of the vehicle, diagrams of the electrical equipment (wiring) of the car.
The manual: 2008
Book format: PDF
