Engines Toyota 1NZ-FE, 2NZ-FE manual repair, maintenance and operation
Guidance on repair, maintenance, operation and installation of the Toyota engine 2NZ-FE (1.3 l) and 1NZ-FE (1.5 l) with distributed injection of fuel, which was installed on a Toyota issue since 1999, as well as modifying them installed on car model: Corolla, Runx, Allex, Fielder, Platz, Corolla Spacio, Vitz, Yaris, Echo, Funcargo, Porte, Vios, Raum, Scion xA, bB, Scion xB, Probox, Succeed, Ractis, Will VS Will Cypha, Will Vi, Ist, Sienta, Belta, Premio, Rumion, Allion.
This manual contains information concerning the diagnosis and repair mechanisms of the engine elements, fuel injection systems and variable valve timing (WT-i), as well as ignition, starting and charging car, guide to use the system self diagnosis.
