GAZ 69-68 manual repair and maintenance
![](https://book4car.net/book_cover/gaz_69-68_manual.jpg)
GAZ 69-68 - manual repair, maintenance and operation of the vehicle.
The guide is intended for the personnel of the maintenance units and doing minor repairs to the front of the car on the finished units. In addition, this Guide can be used for conducting practical.lessons on military car GAZ-69-68 in military schools and units. This manual applies to the car GAZ-69-68 and following modifications, produced by the Ulyanovsk automobile plant:
— GAS-69-68 — eight-terrain vehicles for transport of personnel and cargo;
— GAZ-69A-68 — five-seat off-road vehicle for the transport of personnel;
— GAZ-69E-68 — eight-terrain vehicles with shielded electrical equipment to transport personnel and cargo;
— GAS-69АЭ-68 — five-seat terrain vehicles with shielded electrical equipment to transport personnel.
When developing the Manual into account structural changes of the GAZ-69-68 and its modifications that affect the production of the current and medium repairs made prior to August 1, 1971
The manual contains: - General instructions, including instructions for special handling of the car before repair works are conducted in time of war; - the first part - operational maps for the replacement of major units, assemblies and devices, indicating the grounds for the replacement and technical specifications for the Assembly, as well as requirements for painting and test of the car; - the second part - operational maps for the repair of units, assemblies and devices with technical specifications to Troubleshooting and repair of parts, reassembly, Assembly, or device; - application
Operating maps shall include all work performed when replacing, disassembly and Assembly units and units. If you replace any unit or host, you must first remove or install another machine or node, in operating the map is a reference to the map. While operating the map indicates the total time spent on execution of all work (except time adjustment performed if necessary), and provides all the necessary devices and tools. Operating maps are given without including time for preparatory work. Structural changes of aggregates, nodes and details are given in notes to the relevant passages of the operating cards. Tools and devices needed to perform replacement or repair of units, assemblies and parts, with design changes, are given in parentheses. When performing work on the transition by two or more performers referred to in the text of transition in parentheses.
Publisher: "Voenizdat", DjVu, DOC
![](https://www.book4car.net/images/download-free-now.png)
