TOYOTA HI-ACE 2WD-4WD Diesel (1989-2001) repair manual
TOYOTA HI-ACE 2WD & 4WD Diesel 1989-2001 - manual repair, maintenance and operation of the vehicle.
Repair manual, operation and maintenance TOYOTA HI-ACE 2WD & 4WD 1989-2001 release with right-hand and left-hand steering, equipped with a diesel engine 2L (2.4 l), 3L (2.8 l), 5L (3.0 ltr.), 2L-T (2.4 l turbo), 2L-TE (2.4 l turbocharged and electronic engine management system) and 1KZ-TE (3.0 litre with turbocharging and electronic engine management system).
The publication contains detailed information on the diagnosis, repair and adjustment of the engine, injection pump, systems, starting and charging, instructions for using the self-diagnosis of electronic engine control (EFI), automatic transmission, TEMS and ABS, recommendations for adjustment of mechanical and automatic transmissions, control systems four-wheel drive. In the publication discussed various options for construction of front and rear suspension.
Lists the possible malfunctions and methods of their elimination, mating dimensions of the main parts and limits of their allowable wear, recommended lubricants and working fluids.
Presented detailed diagrams of electrical equipment.
The book is intended for owners of Toyota hi-ACE, the staff of service stations and repair shops.
ISBN 5-88850-157-3
