Toyota SPRINTER CARIB (1995-2001) workshop manual
Workshop manual, service and maintenance of car Toyota SPRINTER CARIB 1995-2001 model years. In this guide, the phased description of the work on operation, repair and maintenance of the RHD Toyota SPRINTER CARIB, which equipped with internal combustion engines 4A-FE (1.6 l), 4A-GE (1.6 l) and 7A-FE (1.8 liter).
The book contains detailed information on repair and adjustment of control system of gasoline engines (fuel injection and ignition), instructions for using the system self-test automatic transmission and ABS. Recommendations for adjustment and repair of mechanical and automatic transmissions, brake components (including ABS) and power steering. Presents detailed wiring diagrams for all possible configurations of cars!!!
Lists the possible malfunctions and methods of their self-elimination, the mating dimensions of the main parts and limits of their allowable wear, are recommended lubricants and working fluids.
