Land Rover RAVE (Technical Data) on Range Rover / Classic / New, Defender, Discovery I/II, Freelander [2002, MM]
Dealer information base Land Rover Technical Data (RAVE) contains information on repair, maintenance, diagnostics, wiring diagrams, body dimensions, etc. for car Land Rover and Range Rover.
In the program of Land Rover Technical Data (RAVE) provides detailed instructions on installation, dismantle, disassembly, Assembly, adjustment and configuration of various components and assemblies of the car company Land Rover, also represented the norm-watches, color wiring diagrams, pin out connectors, body dimensions and manual for auto body repair. The program comes on three CDs (three discs).
The interface of the program of Land Rover Technical Data (RAVE) is built based on Adobe Acrobat Reader and is seamless when working.
Install the program does not require, after starting with the CD creates a shortcut on the ""Desktop"," and then works by using CD. All information is presented in English only.
The model presented in the program of Land Rover Technical Data Rave:
Range Rover Classic
New Range Rover L322
The p38a Range Rover
Land Rover Defender
Land Rover Discovery
Land Rover Discovery II
Land Rover Freelander 1998-2000
Land Rover Freelander 2001-2004
Additional information: you can copy the directory with the program from the CD image on local disk.
Version: 03.2002
