Renault 21 (Nevada) repair manual
Renault 21 (Nevada) - manual repair, maintenance and operation of the vehicle.
The guide will help You to determine what you need to do the job even if you decide You can accomplish it in a workshop, diagnose and provide information on the technical condition, determine sequence of operations and diagnostics for maintenance or repair.
The CONTENTS
Service and maintenance of cars “Renault 21 ” and “Nevada"
1721 CC (TL,TS,GTS,RS,TSC)
The practical and technical information
1. Engine
Detailed description
Adjustment
Ignition
The fuel pump
Carb
Removing the engine
Disassembly of the engine
Engine mounting
A distribution mechanism
Lubrication system
Cooling system
2. Engines J7R 750, 751
3. The RENIX injection system-BEND1X
4. Grip
5. Transmission, differential mechanism
6. Transmission
7. Control mechanism
Steering
8. Suspension, front axle, hub
9. Suspension, rear axle, hub
10. Brake
11. Electrical equipment
12. Wheel
Evolution of design models “Renault 21” 1721 CC from 1987 to 1989
Evolution of design models “Renault 21” 1721 CC from 1990
