BMW 5er E34 1989-1995 - Bedienungsanleitung, Reparatur und Wartung des Fahrzeugs.
Service Anleitung (Service Manual) für die Reparatur und Wartung von Auto BMW 5-Serie E34 Modelle 1989 - 1995 Baujahr: 525i, 530i, 535i, 540i einschließlich Touring.
The BMW 5 Series (E34) Service Manual: 1989-1995 is a comprehensive, single source of information and service specifications available specifically for BMW 5 Series from 1989 to 1995. The aim throughout this manual has been simplicity, clarity and completeness, with practical explanations, step-by-step procedures and accurate specifications. Whether you ' re a professional or a do-it-yourself-BMW-owner, this manual will help you understand, and repair care for your E34 5 Series.
Though the do-it-yourself-BMW-owner will find this manual indispensable as a source of detailed maintenance and repair information, the BMW owner who has no intention of working on his or her car will find that reading and owning this manual will make it possible to discuss repairs more intelligently with a professional technician.
Models engines and covered:
525i (M20 with DME 1.3) 1989-1990
525i (M50 with DME 3.1) 1991-1992
525i (M50TU/VANOS with DME 3.3.1) 1993-1995
530i (M60 with DME 3.3) 1994-1995
535i (M30 with DME 1.3) 1989-1993
540i (M60 with DME 3.3) 1994-1995
Transmissions covered:
Manual (remove, install external service)
Getrag 260/5 and 260/6
Getrag S5D 250G
Getrag S6S 560G
Automatic (remove, install external service)
ZF 4HP22/EH
A4S 310R (THM-R1)
ZF A5S 310Z
ZF A5S 560Z
Technical highlights:
Maintenance procedures brake fluid from changes to resetting the Service Indicator. This manual tells you what to do, how and when to do it, and why it ' s important.
Engine and cylinder head service, repair and reconditioning, including M50 and M60 timing chain setup and adjustment.
Extensive management engine specific information for BMW 5-Series driveability problems, including reading Check Engine light fault codes.
Transmission maintenance, troubleshooting, adjustment and repair, including hydraulic clutch, Schalthebel linkage, and driveshaft.
Body adjustments and repairs, including Schiebedach sedan removal and adjustment.
Heating and air conditioning repair, including A/C micro-filter and A/C component replacement.
Wiring schematics for all circuits, including power distribution, grounds, and component locations.
Comprehensive BMW factory tolerances, wear limits, adjustments, and tightening torques that you ' ve come to expect from Bentley manuals.
