Turbo: Building and Tuning Turbocharger Systems for Maximum Horsepower is the most complete, detailed, up-to-date resource on anything and everything to do with turbos. Whether you ' re running gas or diesel, 4,6,8, or more cylinders, this book will teach you to design, test, install, and maintain your high-performance turbo system.
Learn how turbochargers work, how to choose the right turbo or turbos for your engine by reading flow maps, and how to tune your engine to run perfectly with your turbo system. Author Джей Милър uses над 300 photos and the perfect blend of technical and common-sense information help you build boost technology fast and build horsepower and torque.
He discusses the various components of a turbocharger and explains how to tell which compressor, turbine, and bearings come in which turbos based on their often complicated model numbers. If you run into problems with your turbo system, there ' s also a detailed chapter on failure analysis to help you figure out what went wrong and how to fix it--plus a complete step-by-step turbocharger сълза-down and rebuild.
Издателство: Car Tech
Автор: Джей Милър K.
Серия публикации: S-A Design
