Turbo: Building and Tuning Turbocharger Systems for Maximum Horsepower is the most complete, detailed, up-to-date resource on midagi, and everything to do with turbos. Whether you ' re running gas or diesel, 4,6,8, or more cylinders, this will book teach you to design, test, install and maintain your high-performance turbo system.
Learn how turbochargers work, how to choose the right turbo or turbos for your engine by reading flow maps and how to tune your engine to run perfectly with your system turbo. Author Jay Miller uses üle 300 photos and the perfect blend of technical and common-sense information help you build boost fast and build horsepower and torque.
He discusses the various components of a turbocharger and explains how to tell which compressor, turbine, and bearings come in which turbos based on their often keerulised model numbers. If you run into problems with your system turbo, there ' s also a detailed chapter on failure analysis to help you figure out what went wrong and how to fix it--plus a complete step-by-step turbocharger tear down and rebuild.
Kirjastus: Car Tech
Autor: Jay K. Miller
Publikatsioonide seeria: S-A Design
